John Deere 5425 Starting/Fuel System Problems
/ John Deere 5425 Starting/Fuel System Problems #1
Dorie L
Just wondering if anyone has experienced problems starting their 5325, 5425 or 5525 Deere and keeping it running. Have a tractor that will crank and start, runs for 3 seconds, RPM's fall off/surge, dies, and won't restart. This is after it has been setting for a few days. Fuel system must be bled to get it to run. Please elaborate if you have experience similar problems. Thank You.
/ John Deere 5425 Starting/Fuel System Problems #2
I would check all the rubber hoses for any wear or pinholes, I feel like you are getting air into the system and losing prime from sitting. I was working on a backhoe that would do that. I replaced the fuel hose from the tank to the fuel pump and not had anymore problems.
The entire fuel system has been replaced with the exception of the tank and adding
an electric pump.
/ John Deere 5425 Starting/Fuel System Problems #4
I got a 5325, no problem starting, just electrical problems, blowing fuses.
2009 Ford F-250 4x4 Crew Cab Pickup Truck (A61568)
2009 Ford F-250...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
2004 PROCO 130BBL VACUUM TRAILER (A60736)
2004 PROCO 130BBL...
23105 (A56859)
23105 (A56859)
2012 Volvo BL70B (A60462)
2012 Volvo BL70B...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
