John Deere 5420 problem
   / John Deere 5420 problem #1
astralplane
Renick, WV
John Deere 5095M 4WD
I own a John Deere 5420 and recently had an experience that scared the **** out of me. I placed the Powershifter in Park and when I released the clutch the tractor took off in forward direction. I was in low range and 2nd gear when this happened. I immediately hit the clutch and brake and looked to see if the shifter was in park and it was. I shifted to neutral and back into park and the same thing happened again. It took 4 tries for the transmission to finally to actually go into park. Has this happened to anybody else out there? This makes me want to trade my Deere for something else!
   / John Deere 5420 problem #2
Welcome to TBN. Great place, cheap advice..
I can appreciate your consternation and alarm! However, before you get ready to sell or trade - call your local JD's service manager.
Chances are he or the shop mechanics have some knowledge of your problem and can offer solutions.
At the very least, he can access the JD database for prior recalls, retrofits and/or repairs for the problem you experienced.
Best of luck.
AKfish
   / John Deere 5420 problem #3
I agree that you should contact your local JD dealer service manager. They should be able to contact D-Tac at JD service dept at the branch office to find solution. I'm guessing a control assembly malfunction as JD shows a retro-fit linkage in parts catalog with original parts NLA(if I'm looking at correct handle).
   / John Deere 5420 problem #4
The lever mechanism has 2 cables. Probably one has broken. Relatively simple fix. Not too technical, just getting to and routing the cable is the time.
   / John Deere 5420 problem #5
Just re-read your post. Maybe lube the mechanism with some lube. Make sure the latches and such are working. Agreed this is potentially dangerous. Keep us posted on outcome.
   / John Deere 5420 problem #6
So what was wrong?
I haven't had an issue with mine in nearly 1000 hours and hope that I don't. We have to put a lot of faith in that PARK position seeing that it doesn't have a park brake.
The problem was a broken parking pawl and gear. The total bill to fix the problem was $2,971.00. The dealer said it is not uncommon for this to happen if the tractor is not completely stopped and you attempt to put it in park. I must admit that on more than a few occasions I have heard a grinding noise when I've tried to put the tractor in park. You can bet your rear end when I put it in park from now on, the tractor will be completely stopped. This was a very expensive lesson to learn! Overall this tractor has been a great piece of equipment. I'm almost ready to pull the trigger on a 3 point backhoe attachment for it. Anybody out there have any experience with 3 point backhoes?
   / John Deere 5420 problem #8
any brand will break if you put it in park with it still moving.on my 5510, john deere replaced my linkage on a recall.it now has over 3500 hours with no transmission problems.the backhoe attachment works good but not as good as a real backhoe.
   / John Deere 5420 problem #9
Ummm, broken pawl and gear not all that uncommon??? YIKES!
You probably have the same issue I have. Not a single piece of flat ground anywhere on your property to park. Everytime I am making hay and have to stop with the baler and hay wagon on, I think to myself: "I hope the parking pawl holds". Now, you really have me thinking... Obviously I try not to stop on steep ground, but I rarely can find completely flat either. I will have to be more cautious.
Looking at the parts schematic on JD Parts, it appears that there is no way to inspect the pawl and gear without splitting the tractor, dropping the transmission and removing the top cover. Althogh, maybe there is a side access cover that will allow inspection.
Do you know if they could see the pawl and gear via the side access cover?
Based on my conversations with a JD mechanic, there is no way to inspect the parking pawl without breaking the tractor in half. He also said to try not to park on a steep incline because it puts an extraordinary amount of strain on the pawl. I cut brush with a 7 foot rotary cutter on some very steep areas of my farm and sometimes it is necessary to stop on a hill for various reasons. It takes a leap of faith to trust that the tractor won't run over you as you work around it. I'm as careful as possible but I do worry when I have to work downhill in front of the tractor. I always work with my loader bucket attached and drop the bucket at an angle when stopping downhill as a safety measure.
2017 TAKEUCHI TB240 HYDRAULIC EXCAVATOR SN:124002932 powered by diesel engine, equipped with Cab, (A40020)
2017 TAKEUCHI...
2010 Ford Fusion Sedan (A44572)
2010 Ford Fusion...
2017 Kubota M5660SU-D 4WD Tractor (A42742)
2017 Kubota...
Super Cotton Packer Module Builder (A40783)
Super Cotton...
7078 (A39855)
7078 (A39855)
Pittsburg 3pt 2 Row Cultivator (A40784)
Pittsburg 3pt 2...
