John Deere 5415 Brake light
   / John Deere 5415 Brake light #1
Stephanj
South Africa
John Deere
I have a 2006 John Deere 5415 open station. The handbrake indicator light on the instrument panel is not working. I have checked the bulb is OK. It must be a wiring fault. I understand that the light will only work when the engine is running. All the wires are in the harness and is difficult to trace without cutting the harness. Where does the signal wire terminate on the handbrake? Is there a limit switch which could be faulty? Does anyone have a wiring diagram of the tractor electrical circuits?
   / John Deere 5415 Brake light #2
Welcome to TractorByNet. :tractor:
   / John Deere 5415 Brake light #4
Welcome to TBN
   / John Deere 5415 Brake light #5
Welcome to TractorByNet!
I moved your thread to the John Deere Owning & Operating forum. :)
   / John Deere 5415 Brake light #6
Usually on the 5000 series, the park light indicator never lights up. Its just there for some reason. :confused3:
Thank you for this information.
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
New Holland B95 Backhoe (A50490)
New Holland B95...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
