john deere 5400 will not go in gear
   / john deere 5400 will not go in gear #1
galleranch
houston tx
john deere 5400
i have a 1996 john deere 5400 4wd. when i run tractor and switch gears to reverse, nothing happens. I increase rpm's and motor revs up with no movement. It takes several minutes of switching gears for it to go into gear. Does anyone have any recommendations of how i can fix this problem or see whts wrong.
   / john deere 5400 will not go in gear #2
I will admit I will not be a lot of help, but you may want to post your question in the John Deere Owning/Operating forum. Some other information would be helpful the type of transmission as tractordata.com shows three types of transmissions, number of hours on the tractor, amount of free play in the clutch and amount of free play in the clutch remaining.
Selectmanuals.com has technical manuals on your tractor.
2019 John Deere 5055E Tractor (A49339)
2019 John Deere...
Farmall M 2WD Tractor (A49251)
Farmall M 2WD...
2014 Dodge Journey SUV (A46684)
2014 Dodge Journey...
2008 Toyota RAV4 Limited 4x4 SUV (A46684)
2008 Toyota RAV4...
2018 Schulte FX107 84in Rotary Cutter Attachment (A46683)
2018 Schulte FX107...
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
