John Deere 5400 3 point hitch lower links removal
   / John Deere 5400 3 point hitch lower links removal #1
voyager3
John Deere 5400
The nuts holding the lower links on the balls won't budge with a breaker bar and laugh at WD40. I wanted to check that there isn't supposed to be any red loctite on them before breaking out the 3/4" breaker with a pipe.
And while I have your attention, what is the tightening torque supposed to be? I only found the generic torques per size and grade in the manual.
   / John Deere 5400 3 point hitch lower links removal #2
Grab a propane or MAPP gas torch and give them a little heat. If they still won't budge, a bigger breaker bar/impact gun is necessary. If that doesnt work, cut them off with a torch, they don't argue if they're liquid. sometimes its cheaper to replace a part than to try to save it.
   / John Deere 5400 3 point hitch lower links removal #3
I second the torch part. Grampa used to call torches the blue flame ratchet
Thanks, turns out there wasn't any threadlocker used. I got myself a shiny new stubby air impact which did fit in the space available and busted the nuts with contemptuous ease. Now I wonder if I've grown weak or whether the impact action is in fact as magical as people say.
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
KMC 5610 (A53084)
KMC 5610 (A53084)
Miles read : 112,969 (A50323)
Miles read ...
2016 MITSUBISHI OUTLANDER SPORT (A52472)
2016 MITSUBISHI...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
