jonnygorgo
While using the my tractor I heard and felt a loud "pop" after which I could not curl the bucket of the loader.
The steering, lift arm and the three point hitch work fine.
No leaks.
When this happened last year with the lift arm, I found the cable from the joystick had snapped, so this time I replaced the other cable, but that was not the problem.
After some research on this site I realized that I can switch the quick connects on the back of the tractor and if the lift still works, then I have isolated the problem to the hydraulic pistons on the loader. If the lift does not work when I switch the lines, and the bucket curls, what does that mean?
My internet connection is 45 miles from the tractor, so I would appreciate any suggestions on how to troubleshoot this before I head back out there.
Thank you!
No leaks.
Thank you!
