Dan Dargeloh
I have a 2008 JD 5303, equipped with a Westendorf loader and power beyond. When I move the 3pt lever all the way to the rear (with the draft control lever in the off position), the 3pt comes up and stops as it should, but the hydraulics are still pumping against the relief valve, most of the time. Once in awhile it will release and quit trying to raise the way it should, but if it doesn't, just a gentle tap or nudge on the lever will cause the pressure to drop off as it should. After about 30 or so seconds the pressure will start to build again until it is again activating the pressure relief valve. It also will do this when operating at less that maximum height, with something heavy like a shredder or my 110 gallon sprayer on the rear. It's not as noticeable then as the pressure will drop off as it should, but then slowly build up to where it is actuating the relief valve. This is causing the oil to heat up, loading the engine, and causing strain on the pump and me. Any adjustments I can find on the outside have to do with the draft control and do not have any effect on this. The local Deere dealer has been of little help as they deal mainly in the big stuff around here. Any ideas or suggestion? Thank you!
