John Deere 5210
   / John Deere 5210 #1
Alan v
John Deere 5210
John Deere 5210 I purchased this and changed the filter And topped off fluid. It first appeared to work fine and then the steering and lift arms would not function. Not familiar with hydraulics. Any thoughts. Thank you
   / John Deere 5210 #2
Is the fluid still showing full on the stick? I had a 5310 that I changed the filter on once I think. I'm not sure I lost enough to even add any.
   / John Deere 5210 #3
Since it happened after you changed the filter I would think it has to be related.
   / John Deere 5210
Is there a simple way to bleed out air. I suspect the filter change introduced air. I thought it may purge by running the system or turning the steering back and forth.
   / John Deere 5210 #5
A bad seal on a hydraulic filter is a possibility. A common error is a doubled up gasket. The old gasket can separate from the filter and stay on the tractor, then the new filter and gasket won't seal properly.
   / John Deere 5210 #6
It should purge itself out. I don't know of any way to purge air. I sold my tech manual when I sold my 5310 so I can't check and see if there is anything about it in the manual. Is the steering doing nothing or just hard to turn? I would think if your fluid is correct and you can operate thing to some degree, run it and see if it starts getting better.
   / John Deere 5210 #7
I would think it would be leaking if that were the issue. This tractor has a spin on filter like an auto oil filter.
   / John Deere 5210 #8
The spin on filters are the type I was referring to, but yes, I would assume it would be leaking also.
I used an aftermarket (spin on) suction filter on one of my diesel zero turns several years ago and the hst wouldn’t operate at all. There were no fluid leaks, but I don’t know exactly why it caused problems. The oem filter fixed that issue.
   / John Deere 5210 #9
Good point. It could be the filter if it's not OEM. I never put aftermarket parts on my JD tractors or ZTs.
   / John Deere 5210
I did check to see that old gasket was removed. No leaks. Oem Napa filter. The lift arms do very slowly raise and I can feel them trying to raise. They did suddenly jump up a little once. Steering is hard to turn. Feels like no assist.
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A52748)
2020 Westfield MKX...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A52748)
2017 KINZE...
