May 12, 2014 / John DEERE 5200 tractor keeps moveing after cluch is pressed. #1 B boho New member Joined Apr 13, 2014 Messages 4 Location kennett square, pa Tractor john deere 5200 My John Deere 5200 tractor keeps moveing when I press the cluch in and apply the brakes. Happens when the tractor has a load on its. Anyone have this problem with there 5200?
May 13, 2014 / John DEERE 5200 tractor keeps moveing after cluch is pressed. #2 Tx Jim New Member Joined Jan 26, 2007 Messages 10,238 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC Have you checked clutch pedal free travel? It's possible the clutch plate is warped. JD 5000 series tractors have a long history of clutch problems.
May 13, 2014 / John DEERE 5200 tractor keeps moveing after cluch is pressed. Thread Starter #3 OP B boho New member Joined Apr 13, 2014 Messages 4 Location kennett square, pa Tractor john deere 5200 Thank Tx Jim. I did check the play. Do you know if it is hard to put a new cluch in this JD 5200.
