John Deere 5105
   / John Deere 5105 #1
Ed Olson
Marcell, Minnesota
John Deere 5105
My 2002 JD 5105 starts runs soft for a moment then quits. Tried it the next day, cooled off, ran for a while. Ideas?Thanks
   / John Deere 5105 #2
First would suggest checking out your fuel supply... filter, water collector, etc.
Have you the service technical manual?
:welcome: to TBN
   / John Deere 5105 #3
Since it has to sit for awhile before it restarts, I would say you have some junk in you fuel tank and after it sits for awhile the junk floats up.
I would start with the easy things, before cleaning the tank out. Put a voltmeter at the fuel solenoid and make sure you are not losing power there. Open the fuel cap to make sure you do not have a vacuum issue, the vent behind the tank could be plugged up. Make sure the air filter(s) are clean.
Replace the fuel filter, fill the filter before you put it on and have a full tank. Doing these 2 things I have never had to bleed my tractor after changing the fuel filter. We have the same engine and fuel system.
I have included a diagram of the starting system should you need it.
Look at selectmanuals.com for a tech manual.
  • 5105starting_system.pdf
2020 Cadillac Escalade 4x4 SUV (A50324)
2020 Cadillac...
Tillit 3 pt Tiller (A50515)
Tillit 3 pt Tiller...
400 gal Fuel Barrel on Skid (A50515)
400 gal Fuel...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2018 ATLAS COPCO V4-4 BULB LIGHT PLANT/GENERATOR (A51243)
2018 ATLAS COPCO...
