WARTIGER45
Today I was using the disc harrow and noticed the RPM's were fluctuating up periodically. I noticed this before while brush cutting but today seemed more evident. It would only rise but never go below from where I had the throttle arm located. Then as I pull it under the pole barn I turned the key off but the tractor did NOT turn off!!! It was just pitter-patting until it finally cut off. Can someone help me out on this? Is it air in the fuel lines or what? Thank you for all your help in advance.
