John Deere 5075E will not start
   / John Deere 5075E will not start #1
geojr7793
I have a John Deere 5075E that will not start. New battery, new negative cable, all contacts cleaned, starter has been checked out as good, new ignition switch. When you engage the starter switch at first position console lights up and starter beep occurs. When you engage the starter switch to the start position you get a click and a very brief surge to starter solenoid/motor and all goes completely dead. When I disconnect and re-connect the battery the tractor will do exactly the same thing. AI suggest a replaceable diode is the problem (Part #LVU804171). Has anyone had this problem or know where this diode is located. Thank you
   / John Deere 5075E will not start #2
I had a friend that had something and it was a diode. An older tractor then yours and I have no idea where it is.
   / John Deere 5075E will not start #3
Even though battery is new I still recommend load testing your battery. Have you ever attempted to "jump start" your tractors engine? If not I recommend performing that task by CAREFULLY attaching jumper cable/box cables to tractor battery + to + & - to -.
Payment Instructions (A55272)
Payment...
2017 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2017 Elgin Broom...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
2015 SKY TRAK 6036 TELEHANDLER (A58018)
2015 SKY TRAK 6036...
BARBED WIRE (A58214)
