John deere 5020 advice
   / John deere 5020 advice #1
martyred
Spokane Wa
yanmar ym155d, 79 case 580c
Looking at getting a 5020, it's around a 68 vintage. Any tips from the green tractor gurus? It runs smokes a bit but seems nice for its age. Also the pTo won't stop? Needs ether to start... and I need help, I am looking for the what to look for and the cons if there are any in this model. Fire away and give me your 2 cents...LOL Thanks in advance for all and any helpful tips.;)
   / John deere 5020 advice #2
Tx Jim will respond when he see this and can offer you some good advice. He is a retired Deere shop foreman with lots of xx20 experience. About all I remember about the 5020 is how much better I liked the front axle compared to the 4020, way stronger design.
   / John deere 5020 advice #3
Sounds worn out and ready for a rebuild of the engine and transmission /PTO . Have to be real cheap to not go new at zero percent if you have work for a 5000 series tractor that needs doing.
   / John deere 5020 advice #4
You should figure an engine/clutch/pto rebuild into your purchase price. Most of the people I knew who ran a 5020 felt it was underpowered by about 20-40 horse.
   / John deere 5020 advice #5
The OP is asking about a 5020 1968 field tractor not a newer and much smaller utility tractor.
   / John deere 5020 advice #6
I agree that with a tractor this old that you need to consider the major repairs are expensive even if you do it yourself. I would check with the dealer about piston/liners and gaskets to see what availability and cost are. The 6030 that replaced it had 175 hp which does add some power to it.
   / John deere 5020 advice #7
You are correct that the 5020 was in a much different class then the current 5000 series tractors. (totally my ignorance) but if it needs ether to start and the PTO won't shut off then my conclusions still stand.
   / John deere 5020 advice #8
I wouldn't automatically assume it needs an engine rebuild. It may just need some injector work. I don't know about a 5020 exactly but PTO could be most anything but I doubt transmission overhaul. If it turns it's more likely the pto clutch or linkage. I would spend a little $ on having a mechanic check it out before you buy it though.
   / John deere 5020 advice #9
The 5020 is an excellent machine. We had 1 a while back with an aftermarket turbo installed. With the turbo she turned 220 hp. They were strong machines back in the day. I wish you best of luck with it
Thank you all. I hoping to get something going on that! Thanks for your input.
2007 VOLVO VNL DAY CAB (A52577)
2007 VOLVO VNL DAY...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
Kubota BX2230D (A47384)
Kubota BX2230D...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
