John Deere 500c - Dashboard Guages
   / John Deere 500c - Dashboard Guages #1
JeffroL
Bronze Member
Sperryville
Deutz D4006; Kubota M7060; John Deere 500C
I picked up a John Deer 500c several months back. She runs great, starts right up every time, hydraulics are strong with no leaks (once I replaced a few hoses). BUT I do have one issue:
The instrument panel on the machine is dead. Looks like someone shorted it out at some point and/or just cut everything out. Every cable is cut. Nothing works.
The only gauges I really wish I could revive are the oil pressure and temperature sensor, I can live without RPM, etc. I can't find out anything about this engine. Where the sensors go, how to get a replacement, etc.
Does anyone have any ideas? Is there an easy after-market solution? I really just want to know if the machine is suffering low oil pressure or overheating for some reason. Everything else I can live without.
   / John Deere 500c - Dashboard Guages #2
Take a look at jdparts
John Deere - Parts Catalog
and looks like oil pressure lines, wiring, as well as the temp gauge can be bought.
Look under model 500c and then the listing for Instrument panel and oil pressure gauge.
Yes, I've seen the actual parts. But I'm unfortunately in a situation where my local deal won't touch the 500c, and I have no existing wiring to work with. So the question is, for example, where does the thermostat probe even go on the engine? I have no clue and I can't find any schematics of even engine specifications / layout anywhere.
   / John Deere 500c - Dashboard Guages #4
IIRC the engine temp sensor would be at the rear of engine cyl head & the oil sensor would be on RH rear of engine by crankcase vent tube.
2020 KUBOTA RTV...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
