John Deere 5 bottom semi-mount plow
   / John Deere 5 bottom semi-mount plow #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Recently I purchased 2 different Ford 101 3 bottom plows to restore. I was planning on using them with my Ford 7710 FWA tractor. In researching the setup, I learned that the wheel spacing on my 7710 was not correct to run the 101 properly. Seem a 4000 series tractor would be better. A friend of mine has this Deere 5 bottom semi mount plow and has offered it to me for nearly nothing provided I will drive 100 miles to pick it up.
1) Is this a good plow?
2) Will my tractor handle it?
   / John Deere 5 bottom semi-mount plow #2
had one exactly like that in the UK . Covered a lot of ground quickly but with little finesse , boards were a bad shape compared to other ploughs we had at the time like ransomes or kverneland , Used on a ford 6600 most of the time .
   / John Deere 5 bottom semi-mount plow #3
That style was the last decent plow John Deere made. Unless you are plowing heavy crop residue, it should work well.
   / John Deere 5 bottom semi-mount plow #4
I just bought a 3 IH bottom semi mount and for the same reasons. The smaller old style plows wont track correctly. I haven't used it yet.
(2) 24" W X 5 1/2L HEAVY DUTY FOLD UP TRAILER RAMP (A51247)
(2) 24" W X 5 1/2L...
2019 Bobcat T590 (A50123)
2019 Bobcat T590...
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
TIRE TOOLS, BUNGIE CORDS, BALL HITCH (A53843)
TIRE TOOLS, BUNGIE...
Kubota RTV X900 (A50123)
Kubota RTV X900...
UNUSED RAYTREE RMSG29-29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
