Rims John Deere 4x20 Series Wheel Specs Needed
   / John Deere 4x20 Series Wheel Specs Needed #1
TugCaptain
Downeast Maine
2011 John Deere 4120
Good morning
Hoping you all might be able to help me out - I've searched extensively and can't come up with two important specs for my JD 4120:
- Front & rear wheel specifications - I have 10-16.5 R4s and I know they are 16.5" diameter rims. Really looking for the bolt circle and hub diameter
- Rear specs same as front, currently 17.5-24 R4s
- Front to back gear ratio. I know I can get close by using the tire specs, but I'd like to know the exact factory ratio so I can stay within the 5% front overdrive
As you can imagine I am gathering information to piece together a different set of tires. Michelin makes a nice set of fronts with r1 tread with the toughness and load capacity of the r4s I have. Trouble is, I need 8x16 wheels for the width of these tires and JD only made 6x16 wheels for my machine with the R1 option. Basically looking for the floatation and load capacity of my r4s with R1 tread - It's possible, just need wheel specs and axle ratio data
Thanks for any help!
   / John Deere 4x20 Series Wheel Specs Needed #2
Go see Peter at Complete Tire in Ellsworth. He can usually get what you need, their # is 667-5344.
David
David
Thanks - I'll check them out next time I'm in town
2010 Toyota Corolla Sedan (A50324)
2010 Toyota...
Kohler Generator (A50322)
Kohler Generator...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
