Price Check John Deere 47" Snowblower (for JD2320)
   / John Deere 47" Snowblower (for JD2320) #1
lost in wisconsin
Wisconsin
John Deere 2520 (2011)
I was at the dealer earlier this week picking up some supplies when I happened so see a 47" snowblower sitting next to the new ones still in the crate. When I inquired, the salesman informed me someone had upgraded to the 54".
Dealer is asking $2400 for the entire setup including hydraulic chute control. Btw...it came off a JD 2320, which is the same as we have so there should be no needs for additional hardware.
Thoughts? Seems just a bit too high but honestly, I was suprised to see a used one. It is the first I have seen in this area all year.
   / John Deere 47" Snowblower (for JD2320) #2
Our New Buhler/Farmking 50 inch with manual chute is $1995 + modest shipping. Ken Sweet
   / John Deere 47" Snowblower (for JD2320) #3
I'm sure that new setup is over 3K at most dealers,
so if it's slightly used, might be worthwhile for you since
it's a direct fit , and no crik in your neck! :D
   / John Deere 47" Snowblower (for JD2320) #4
Worth every penny!
I think I saw it the same unit, and it looked to be in real good shape. I actually thought it was a good price. Even though I already have one...for a second I thought maybe I needed two!
I'd already forgot that the next time I saw my neighbors son I was gonna tell him about it.
If you have to move a lot of snow with your 2320, nothing else will even come close.
Joe
   / John Deere 47" Snowblower (for JD2320) #5
   / John Deere 47" Snowblower (for JD2320) #6
I had the 47" blower on my old 2320 and it was excellent in our deep upstate NY snow.
Rob
   / John Deere 47" Snowblower (for JD2320) #7
Lost in WI (good place to be lost :) )
You can rest assured that it will maintain that value, and when the snow flies the salesman will likely have no trouble moving it. It will look better on your 2320 than someone else's. :D
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
3 pt Post Hole Digger (A50515)
3 pt Post Hole...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
2011 Volvo Semi Truck (NOT RUNNING) (A50774)
2011 Volvo Semi...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
