Hi All,
I have a JD 4600. I can not get it to go into 4WD. The linkage is intact and the handle rotates the shaft on the side of the trans. The roll pin is in place and the shaft moves in both directions when the handle is raised or pushed down. I am going to jack up the front wheel and see if it will spin and I am going to check the fluid level in the front axel in a few minutes. I have the Power reverser gear model. I bought this used. I don't know when it stopped working. I do know I needed the 4wd the other day when I got stuck in a ditch, LOL.. Had to pull it out with a pick up truck. LOL
Anyway, typically what is the most common failure on the MF4WD that causes it not to engage? Or where is the first place to look. I looked at the parts breakdown and everything else is internal. No sure that I want to split the tractor but will if I have to.
Thank you!
Thank you!
