tbrooks26
Hey everyone. Finally got some time to work on the JD. I've got the new range shifter rod in, and everything back together enough to run it. I have 2 issues right now. The first I noticed was the light for the glow plugs is not coming on. I looked and searched through the manual for glow plugs, but I can't find anything. It will run with some ether, but I don't think that means the plugs are working. The second main issue is fuel is not going through the injection pump. Now this tractor has been sitting for 5 years, so I'm hoping its just gummed up. I flushed and cleaned the fuel tank, filter, and bowl. I have good clean fuel at the inlet to the pump. I removed the fuel return/bleed line from the filter, and pumped and pumped the mechanical fuel pump lever. I got like one air bubble from the injection pump bleed line, but fuel keeps coming out of the nipple on the fuel filter where the line connects, and I didn't have a cap, so I was making a mess and stopped that. I have removed all the lines from the top of the injection pump, and have nothing there. The manual says these pumps are supposed to be self bleeding, but I may need to do more to help it along. It may even be the internal fuel shutoff. I tested the solenoid and it is definitely working, but I couldn't feel much movement on the lever it pushes. I saw someone on a different tractor removed the side cover on the injection pump, to free the internal shut-off, but not sure if mine is the same. As of now, I blew the fuel out of the pump, and slowly filled it with as much carb cleaner as I could, and have left it to sit for a little while, to hope it breaks things up some. Another issue coming later, is the clutch is frozen, but I've read many threads on that so hopefully that will be an easy fix.
