John Deere 4410e
   / John Deere 4410e #1
542bob
Kintnersville PA
John Deere 4410e
I have a JD 4410e when I push forward or reverse pedals the tractor will not move can anyone tell me the right fusse to change thank up front
   / John Deere 4410e #2
On my 3320, which would be a newer replacement for your tractor, there is a circuit board that corroded and had voltage problems and caused the ehydro system to not function.
   / John Deere 4410e #3
Welcome to TBN,
This issue is most likely much more involved than a simple fuse unfortunately. Start by checking the wiring under the pedals, and seeing what codes are flashing on the display.
You can purchase the CD version of the shop manual for about $100 I think too.
   / John Deere 4410e
Thank u 4 in put I have worked on tractors for many years. But circuit boards o my my 4410 is now in the hands of Detlan JD
   / John Deere 4410e #5
542bob did u fixed your 4410? I have same problem thanks
2021 CATERPILLAR 420 XE BACKHOE (A51246)
2021 CATERPILLAR...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52576)
2019 INTERNATIONAL...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
