John deere 4400 with Hydrostatic drive will only go 6 mph in C range.
   / John deere 4400 with Hydrostatic drive will only go 6 mph in C range. #1
Eddahl11
Montague, Michigan
John Deere 4400
Hi all, I bought the tractor used and already had around 6k in repairs into it. (didn't know what I was buying) Anyway, the specs on the tractor says it should go 15.5 mph in C range and it's top speed is only 6 mph. It doesn't seem to be slipping at all when going up and down slopes or dragging the horse pen. It just doesn't go very fast at all. Can someone please give me an idea what may be wrong? I have checked fluid levels, changed the filter and oil. It just seems like it's not getting the pressure needed to drive the transmission gears fast enough.
Thanks all
Ed Dahl
   / John deere 4400 with Hydrostatic drive will only go 6 mph in C range. #2
Ed,
In hydraulics speed is a function of flow while force is a function of pressure so if it is climbing hills you do not have a pressure problem. First thing I would check is to make sure you are getting full pedal travel in forward. I.e. look for something obstructing the linkage or pedal travel.
   / John deere 4400 with Hydrostatic drive will only go 6 mph in C range. #3
Does it go the proper speed in the other ranges? That might give a clue as to what's wrong.
2019 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A48081)
2019 Chevrolet...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A50860)
2025 K0311 UNUSED...
1994 Mack CH613 Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
