eee
I have had a JD 4400 for over 4 years now. I use the heck out of it and I have had some problems as well. I fix the thing and I go on.The tractor has 1116 hours on the clock.
The safety switch under the seat has failed.
1 fan belt replaced under warranty.
I have bent and replaced the lower lift arms.
I have had to replace the adjusting rod/bar on the left lower lift arm.(broke)
It had a new starter replaced under warranty because of a hard starting issue that was resolved by a piece that was replaced/ installed in the electronics.
I have had an intermitent loose wheel bolt problem.
I have my 3rd differental lock which has failed (about a year ago)I am not going to spend any more money on this part,I can use the steering brakes.
I had to replace both the axle housings.
I have the old style axle and had to replace both tie rod ends ( $210 apiece)
The plastic side covers do not stay in place very well the same with the front grill cover,there is not much holding the covers in place to begin with.One of the ears on the side cover is broken.
The plastic around the ignition switch is cracked.
I had to intall a new seat belt (button came apart)
Last night the speed range selector quit working. I was in the woods and I could not get the tractor into low range or any range,I crawled underneath the tractor and found the part that is pivoted by the handle and was able to get my channel locks on it and turn it,it went into low range. I had to help it with my channel locks one more time and when I got to the house I intentionally moved the selector out of low range and I then could not move it to any range regardless of what I tried to do. It appears I am going to have to tear into the tractor again and fix it right.
I have the 430 loader and 4 in 1 bucket,some of the hoses have been replaced because they are in an area that gets a lot of movement and rubbing on the loader arms.
The Yamnar engine has performed flawlessly ( 1100) The hydro has performed well.
I can't help to wonder if JD is coming out with the new line up of compacts because of the problems associated withe the 4000 and 4010 series.
I always liked green,but if I were to buy another tractor I am going to take the JD binders off and go look at Kubota/CNH/CASE/AGCO/ Massey. A neighbor of mine bought a new Massey Ferguson that is a 29 HP and I could see nothing wrong with it,I do not know if my JD would be a better value than his Massey after comparing the 2 tractors.
The biggest thing that kept me with JD is the strenght of the company and parts availability and the company not merging with anyone else.
I have several JD green implements,if I ever do switch I can paint the implements to match what ever brand I go with.
