John Deere 4400 Hydro need pinion gear front axle
   / John Deere 4400 Hydro need pinion gear front axle #1
tposts
Bronze Member
Anyone know where I could pick up a used or aftermarket pinion gear for a John Deere 4400 hydro ?? I need one and John Deere parts wants $800 for a new one with a ring gear,they will not sell seperate.Post here or IM me either way if you can help.
I would appreciate any help.
Thank you very much.
   / John Deere 4400 Hydro need pinion gear front axle #2
Good luck hunting. Bet it is a JD only part. They don't make them standard sizes so the company can supply the parts. My corporation axle in a 3/4 ton HD Chevrolet truck is GM part replacement only... no aftermarket available. They have been out for ages and in large numbers... go figure.
   / John Deere 4400 Hydro need pinion gear front axle #3
I had to replace them on my Mitsubishi CUT.
Yep, only as pairs.
$800 is not bad.
Even my GMC 3/4ton set cost me $595.
If you find used, be sure to get the set as otherwise you will be looking again.
   / John Deere 4400 Hydro need pinion gear front axle #4
You might try West Kentucky Tractor Parts Inc . They sell a lot of used compact tractor parts. I don't think that you will be able to get any reputable place to sell you just a pinion. They are made as a set and are lapped in that way. If one piece breaks, then both pieces are thrown away.
<font color="blue"> $800 is not bad </font>
I think it is a terrible price to pay,the little tie rod ends are $220 a piece on this tractor.
The rear axle housings are about $275 a piece ( if my memory serves me right) this price is a little more reasonable.
<font color="blue"> If one piece breaks, then both pieces are thrown away. </font>
I see...thanks for explaining.
   / John Deere 4400 Hydro need pinion gear front axle #7
Hey,
When we did the pinion in our MF 35, they came as a pais it is was around $600!! Not too bad considering it will last a long time if not abused!!
Take care,
Will
Landpride RCR1672 Finish Mower (A49251)
Landpride RCR1672...
Early 90's Chevy Van Bus, Dual Wheels (A47371)
Early 90's Chevy...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A48837)
New/Unused 7ft 10...
2011 MCI D4505 TANDEM AXLE PASSENGER BUS (A45679)
2011 MCI D4505...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A48081)
Unused 2025 40ft...
Scraper Blade (A49251)
