John Deere 4310 wont move in 1 direction
   / John Deere 4310 wont move in 1 direction #1
Keegan4123
john deer 4310
I have a 4310 that is having some issues.
I hit a stick tonight and ripped the leads out of the connector on the reverse solenoid.
Shoved them back in and it worked. For about 5 minutes.
Lost reverse but still had forward if i reset the key getting code 10, short-long-long-long. 天alve output to forward or reverse selenoid
I got it back to shop and began trouble shooting. Heres my steps so far:
1. Swap solenoids to ensure both directions of travel was good
2. Swap leads on the selenoids to ensure selenoid function
3. Swap pedal leads to confirm position switch function
4. Trace wires back to ecm
5. Check all fuses
6. Cut connectors and hard wire to selenoid.
I have narrowed it down to the purple/black wires that were pulled out of the connector.
It just doesnt quite make sense, ive traced them back all the way to ecm and there is no shorts.
What now?!? Would love some help, im struggling and my cows are hungry..
   / John Deere 4310 wont move in 1 direction #2
The wires may have been stretched to the point that they broke inside the insulation? Just a thought, do you have a way to check each wire for continuity from one end to the other?
   / John Deere 4310 wont move in 1 direction #3
Sounds like it needs a recalibration. I'll send you document going through the steps on how to do an automatic recalibration.
2022 Club Car...
2017 Kenworth K370 New Way 16RLCN 16Yd Rear Loader Garbage Truck (A48081)
2017 Kenworth K370...
Antonio Carrago TGF9400 Orchard Tractor (A49251)
Antonio Carrago...
2007 John Deere 320 (A47164)
2007 John Deere...
3pt Wood Chipper (A49251)
3pt Wood Chipper...
Headache Rack (A47371)
