John Deere 4300 SyncReverser issue
   / John Deere 4300 SyncReverser issue #1
CT70HKO
Dundee Mi
1999 John Deere 4300 1948 Farmall Super A
i have a 4300 with a SyncReverser transmission. It moves forward and reverse just fine. The issue is while having the forward/reverse lever is in neutral position. The machine drifts rearward. Has anybody had this happen to them? What was the problem? How did you fix it?
background
I bought the tractor from a friend after his brother-in-law passed away. His brother
-in-law used it for mowing. It had 350 hours on it when I bought it. I noticed the drifting at the time and assumed it just needed adjustment. Now I've got 400 hours on it and decided to adjust the clutch. I purchased the technical manual and followed the recommend steps and it still moves rearward. Ive been surfing the forum for sometime now and have only found 1 post with the same issue and nobody
responded.
Thanks,
Eric
   / John Deere 4300 SyncReverser issue #2
Welcome to TBN
It's possible reverse synchronizer's are binding a little. Are you positive linkage is shifting reverser to neutral position?
Thanks for your reply Jim. I wanted to make sure it was in fact in the neutral position, so I disconnected the forward/reverse linkage at the point circled in red. I am able to feel each detent and confident thats its in "neutral".
   / John Deere 4300 SyncReverser issue #4
I once owned a Kubota M4900 with sycnc shuttle that I utilized mostly to handle rd bales that became locked in reverse. I had to split tractor & R&R shuttle assembly.
Misc Machine Tools (A50860)
Misc Machine Tools...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
Auger (A50860)
Auger (A50860)
Utility Trailer (A50860)
Utility Trailer...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
