John deere 4300 no start
   / John deere 4300 no start #1
jdman
Mid Missouri
John Deeres
Wnt out today and my 4300 would not start. Always started fast, temp was 40 degrees but we had 17 the other night. Any ideas
   / John deere 4300 no start #2
Did ya try to pre-heat it? I don't want to start when its 17 outside.:( To pre-heat- push in and turn the key to the "run" positionand hold it for 10-15 seconds. That should start it. Is the battery cranking fast enough to start the tractor?
Just a few thoughts...
   / John deere 4300 no start #3
Did it roll over.. or just nothing?
color of smoke?
Soundguy
I preheated with the key, it turned over fine, battery strong, but I noticed the pre-heat light was not on. Maybe a problem in the pre-heat, but this tractor has been starting at 30 degrees with no preheat.
   / John deere 4300 no start #6
No smoke and no preheat.. I'd investigate to see if glow is working.. should be able to tell by electrical load on each plug. After that is confirmed.. check fuel at the injector lines.. ( be carefull.. )
soundguy
Just went out and looked at fuel filter,red ring is up next to filter, and I see bad things in the filter. I cannot get fuel shufoff to turn to remove filter. Maybe water and is frozen, going to try hair dryer and warm it up
Just went out and removed filter had ice chunks. Drained some bad looking stuff from tank drain. Cleaned and put back together, no help. I wonder if the water has got past the filter and into the injectors?
   / John deere 4300 no start #9
Go to Trator Supply (TSC) and get the winter Diesel treatment for you tractor.
   / John deere 4300 no start #10
At this point.. the red 911 is what I'd get..
soundguy
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
New Holland B95 Backhoe (A50490)
New Holland B95...
2005 Ford Freestar SE Van (A48082)
2005 Ford Freestar...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
