builderbob
- Joined
- Jan 11, 2010
- Messages
- 1
2001 John Deere 4300 with 4 wheel drive and manual transmission. Over the past year the shifter has had issues finding reverse....no slipping...just having trouble actually shifting into gear. Now it simply will not go into gear at all. Replaced mounting hardware at base of shifter as the original pin had been dislodged allowing for a lot of play in the shifter....which I think may have been the culprit. All 3 forward gears and ABC ranges work just fine. I adjusted the clutch pedal sleeve...but still does not work. Any suggestions would be appreciated!
