John Deere 430 L @ G
   / John Deere 430 L @ G #1
dar63
Westminster MD
John Deere 430 L&G
I have a 430 L@G tractor that was manufactured in 1992. When the front PTO is on (no rear PTO) the 10 amp fuse will blow and the engine shuts off. It will blow in 2 minutes of operation or can blow in 20 minutes. If I shut off the PTO ,it will start back up and run fine. I had to rewire part of the tractor when I got it and had to pull the engine to replace a oil seal but it ran fine for two years after that so don't think I messed something up. Most of the safety interlocks have been disabled over the years, I have the service manual for the tractor and see the 10 amp fuse handles mostly the interlocks and warning lights and the 25 amp handles the PTO but that fuse is fine.
Thank you for any help !!!!!
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
80in HD Tooth Bucket with Side Cutters (A51039)
80in HD Tooth...
2013 DOOSAN G25P FORKLIFT (INOPERABLE) (A50854)
2013 DOOSAN G25P...
2013 MACK CXU (A50854)
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
