John Deere 425 starting
   / John Deere 425 starting #1
a.palmer jr.
I recently rebuilt the engine on my 425 John Deere and I tried to get the wiring back the way it was but must have done something wrong because now when I turn the key to "on" the starter turns. Somehow I also seemed to by-pass the brake pedal safety switch also. There appears to be only one way the wiring plugs can be plugged in. Anybody got an answer or a wiring diagram?
I found the answer and thought I'd post it in case anybody else has this problem. The problem was a stuck starter relay, k1 , which is on the circuit board under the dashboard on the right side of the tractor. I pecked on it and it unstuck and the tractor starts normally now, but I'll probably have to buy a new relay in the future.
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
2005 Construction Trailer Specialists BDT-40 Bottom Dump T/A 40ft Trailer (A49461)
2005 Construction...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
Landoll (A50657)
Landoll (A50657)
