Hi
I had a line rust out last year and replaced a section of it .
it was going to the front loader.
After that the line blew off and I repaired it, filled with fluid but apparently not enough because after a few days it stopped going ahead and back the way it should so I shut it down and filled it up according to the amount called for in the manual.
Then I see that the fluid turned cloudy.
I drained everything, changed filters and refilled it.
I still get the same problem.
It seems as if there is air getting in because the fluid will clear up after setting for a while.
After I drive uphill the fluid shows at the bottom end of the sight glass but clear.
I drive back down and it shows over full but cloudy.
I added fluid when it was showing low and clear until almost to the top of the sight glass.
It still goes ahead and back but every few feet it seems to do nothing for a second then goes again.
Then the fluid looks cloudy again.
There are a couple of lines still rusted a bit but it isn't leaking anywhere.
It sets on a clean concrete floor so I would notice even a drop.
Any ideas where, or if air may be getting in or any other things I should look at?
It has a little over 1200 hours on it and has had the fluids changed at or before recommended hours.
thanks
thanks
