john deere 420 with cab
   / john deere 420 with cab #1
chevyflan
john deere gp
I have a john deere 420 with a cab and 47 snow blower does anyone have that set up and been able to get engine heat back to the cab.
   / john deere 420 with cab #3
Iv tried as well to keep exhaust fumes out and bring engine heat in, I even tried running a duct from engine compartment but,,,,,, that didn't work either lol
   / john deere 420 with cab #4
On my 445 I found a reverse flow fan does wonders. Cab is hot even in 5 degree outside temp.
   / john deere 420 with cab #5
I've got a 78 316 with a cab and 18 Vanguard repower . I found a metal / rubber boot vent stack thingy at Menards , fit perfectly over the front grill . Clamped a 3"pvc elbow in it pointed up , reduced to 2" , up and back over the hood into a hinged metal panel on my Cozy cab .I hole sawed the panel and another short 90 pointed up at the front glass . Works great . I have run it 5 years and have had 0 problems with exhaust fumes . I have a stack on the muffler to make sure the exhaust gets away . Between this and the residual heat off engine and hydro it can be shirt sleeves on a sunny day .If I ever develop an exhaust leak it could be a problem , but I keep a very close eye on that . I can slip the pipe off over the hood and have it open in less than a minute to check oil and such .This was one of those experiments that actually worked quite well .
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
71054 (A49346)
71054 (A49346)
71066 (A49346)
71066 (A49346)
2005 JOHN DEERE 5205 TRACTOR (A51222)
2005 JOHN DEERE...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
1240 (A50490)
1240 (A50490)
