I have a 1989 JD420 (Onan P220G-20hp), a long time ago, i was told they switched from a points type ignition to a solid state ignition somewhere between the late 80`s and early 90`s. My problem is, i have no idea when the point vs solid state thing happened, but i want to replace the ignition coil, but i`m unsure of the part number and also if i have points ignition, or solid state ignition. I`m told it does make a difference which coil is used. As far as i am finding out, there ARE, 2 different ignition coils. So if anyone can put into the right direction, and also maybe where i can find a new ignition coil, that would be so appreciated! Thank you fella`s.
