Oil & Fuel John Deere 4120 Thermistor Location
   / John Deere 4120 Thermistor Location #1
kprei
I have a 2007? JD 4120 that will not start. I'm fairly sure it is the thermistor but I am having trouble finding it. I removed the fuse box but it is not located on the back of the fuse box. Does anyone know exactly where it is located on this tractor. I have a service guy coming next week but I would rather do it myself.
   / John Deere 4120 Thermistor Location #2
   / John Deere 4120 Thermistor Location #3
I hope that link BeenThere posted helps, but wiring harnesses change quite a bit...however, checking the fuses and relays may be of help.
That diagram is for the older 4x00 and 4x10 tractors built from 1998 to 2004-2005.
As far as the thermistor location...IF it's used on the newer 4x20 series tractors..good question for your dealer (before the tech comes out). Also, a good time to consider purchase of a Service Manual for the 4x20 series tractors, eh?
I actually printed out that same skematic and pulled the fuse box but the only thing behind the relays are 4 or 5 wires running into the back of the fuse box where the relays plug in. I see little red plastic pieces next to the wires but I assume they are what hold the wire. I wish I had a picture I could post but I am at the office now.
   / John Deere 4120 Thermistor Location #6
Glen Watkins said:
What do these thermistors do and anyone know if they are on the 4x20 series?
I was told by my dealer they supply a higher voltage to the fuel solenoid during starting then backs off to run voltage after the tractor has started. I was having trouble with my 4200 not starting. I actually replaced the fuel solenoid and it worked okay but since this was an intermittent problem it came back. I returned the solenoid and got a thermistor, problem solved. I don't remember what the voltages were I just know they are different from start to run. It is a common problem I guess. When I took the fuse panel out I found the leads for the thermistor had already been replaced once. I bought a spare thermistor they are only a couple dollars. I will put longer leads on so I don't have move the fuse panel anymore.
2001 Trail King TK18LP / TK20LP / TK40LP Paver Special Trailer, VIN # 1TKC027231B046890 (A51572)
2001 Trail King...
2013 JOHN DEERE 470G LC EXCAVATOR (A51246)
2013 JOHN DEERE...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
