John Deere 4120 PTO stops working
   / John Deere 4120 PTO stops working #1
joetgreen
John Deere 4120 Power Reverse
My 2004 JD 4120 pto stops working under a load. Just had the tractor broken in half and pto clutch completely replaced as well as the solenoid valve. None of this has fixed the problem. Any ideas on what else might be causing this issue? All fluids and filters have been replaced also and are clean.
   / John Deere 4120 PTO stops working #2
Welcome to TBN
I suggest you acquire a JD 4120 trach manual if you don't already have access to one. Sounds as if hyd engaged pto clutch isn't receiving sufficient hyd pressure to keep pto clutch engaged. I would guess your tractor has a pto clutch pressure test port.
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
Adams 8 Ton Weigh Hopper (A51039)
Adams 8 Ton Weigh...
(2) 500 GAL WATER TANKS (A50854)
(2) 500 GAL WATER...
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
