john deere 4110 stalling
   / john deere 4110 stalling #1
johndeerehelp
john deere 4110
i have a john deere 4110 thats about 3 yrs old. its been working just fine until couple days ago it started to stall in high gear ( sometimes). if i switch it to low, it picks up a lil bit and carries on smoothly. but at times during an uphill it stalls in high gear and the engine totally shuts off. any ideas? could this be bad fuel, checked the oil, etc, all good. my only guess is bad fuel.
appreciate any responses
   / john deere 4110 stalling #2
Change fuel filter. Disconnect hose from filter and blow air back to tank to clear screen. You are losing power at high loads because the engine cannot get enough fuel. Mine does it every few years, usually the tank screen. Good luck.
thanks man, thats what we thought:p wow that was quick response
   / john deere 4110 stalling #4
Welcome to TBN, Both of you:D
Change that fuel filter and get some fresh fuel...Check that air filter(s) also.
thanks :) nice site :D
thanks guys, you guys were spot on.
changed fuel filter and air filter, oiled it and it's running smoooooooooooooothh!!! thanks again phew!
   / john deere 4110 stalling #7
Thanks for posting back! It's always great to hear that we helped:thumbsup:
the tractor has been doing just fine, did as you guys told me to do, but now occasionally and not very often the tractor stalls for about 5-10 secs. it doesn't come to a full stop, it just stalls and then picks up again when i slow down and wait for a few seconds. it happens at odd times, doesn't really have to be uphill, just on the road or off the road. any ideas?? bad gas?
thanks
   / john deere 4110 stalling #9
Did you blow out the line from the filter to the tank?
sorry for the late rep;ly guys. yes i blew air and still stalls. its gotten worse last 2 days. i changed the filters, everything looks clean except this stalling. could this be bad gas? i was thinking of putting some seafoam in it but i hear it';s bad for the motor. any more hints appreciated. thanks
2014 Crane Carrier Low Entry New Way 31Yd Side Loader Garbage Truck (A48081)
2014 Crane Carrier...
1263 (A50490)
1263 (A50490)
Headache Rack (A50860)
2011 Ford F-150 Ext. Cab Pickup Truck (A48081)
2011 Ford F-150...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
