John Deere 4100 glow plug pre-heating
   / John Deere 4100 glow plug pre-heating #1
JFahey
West Falls NY
Ford 851 Powermaster 2009 TYM T503 cab/loader tractor
I bought a model 4100 deere that is pretty hard to start. I am not sure how to preheat the glow plugs on this tractor. I tried pushing in on the key but it will not budge. Cranks for about 15 or 20 seconds in 60-70 degree weather before it fires up and smokes like crazy for a little bit. After it has been running it fires right up. Any help is greatly appreciated.
   / John Deere 4100 glow plug pre-heating #2
The glow plugs work automatically on the 4100 if working properly. When the key is turned to the on position, pause for 3 seconds before cranking. The glow pug module turns off glow plugs after 3 seconds. Glow plugs also are heating during cranking. You can "trick" the glow plugs to heat longer by putting range lever in gear so engine will not crank. Then turn key to crank position for 15 - 20 seconds before placing gearshift in neutral and cranking normally. If this does not help, then chances are good the glowplugs are not working. The relay may be bad, or glow plugs themselves may be no good.
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2013 FORD F750 26FT BOX TRUCK (A51219)
2013 FORD F750...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
