John Deere 4100 Gear Hydraulic Problem
   / John Deere 4100 Gear Hydraulic Problem #1
Hawg Rider
Winfield, MO
John Deere 4100
I have a 1998 JD 4100 Gear tractor and the hydraulics aren't working all the time. The first time the 3 point wouldn't come up I took it back to the dealer. They replaced the rock shaft and things worked fine for a while then started acting up again. I bought the O-ring kit and replaced all those as the dealer suggested. That worked for a while then had the same issue. I replace the rock shaft again and replaced all the O- rings again and am still having the same issue. The filter screen has been checked and cleaned every time I have worked on it and I have only put in JD hydraulic fluid. Tractor has been serviced every spring since I bought it in 98. Only has 1000 hours on it. I have talked to 3 different Deere dealers service managers and none of them can point me in a direction to solve this problem. Any help will be greatly appreciated.
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
John Deere X740 Mower (A50514)
John Deere X740...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
Loader with IH Brackets (A50515)
Loader with IH...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
