john deere 401C backhoe
   / john deere 401C backhoe #1
darrel koozer
Harpers Ferry, Iowa
John Deere 401C
my back hoe hydralics respond as soon as u pull a lever, however forward & reverse movement of tractor takes about 7-10 seconds before it will move. since transmission & hoe have the same hydralics why does it take so long to move? does it winter & summer. Help.
   / john deere 401C backhoe #3
I'm presume you have routinely serviced hyd filters & sump screen???????????? Reverser is operated from trans pump where the pressure is delayed to help preserve clutch disk from abrupt engagement. IIIRC there's a valve that can be adjusted to decrease clutch engagement time. Other hyd functions operate from frt hyd pump.
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
CAT ENGINE ( NON- RUNNER) (A50854)
CAT ENGINE ( NON-...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
