John Deere 401 C Hydraulic issues.
   / John Deere 401 C Hydraulic issues. #1
hhchopper
mo
John Deere 401C
I have a problem with my 401C hydraulics. I have replaced front pump, charge pump, rebuilt the steering sector, and the tractor barely moves. The hydraulic loader chatters and the steering is tough. I have changed the filters numerous times. Is there a easy place to pull a pressure test. Or does anyone have ony other ideas? I am open for suggestions. The mechanic I had working on it past away from cancer and I am forced to figure this thing out myself..
   / John Deere 401 C Hydraulic issues. #2
You have a closed center hyd system.
TractorData.com John Deere 401C industrial tractor information
You should have pressure at any of the valves IN port.
Hyd chatter could be caused by air leak in the suction hose.
Check also for air in your hyd system. Look in the tank for bubbles.
Find the air leak first and then purge the air by operating the cylinders many times.
   / John Deere 401 C Hydraulic issues. #3
This sounds similar to my issue. Pull your return line for the loader where it goes into the sump, then turn the tractor on and see if you have fluid coming out. If you do your bypassing fluid through the loader valvesand they need to be rebuilt or replaced if you can't get the parts.
2014 Dodge Ram 4500 Versalift Bucket Truck (A52377)
2014 Dodge Ram...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
Chevrolet Tahoe SUV (A52377)
Chevrolet Tahoe...
