John Deere 3x20 CAB Model Rear Diverter Kit
   / John Deere 3x20 CAB Model Rear Diverter Kit #1
kennyd
Advertiser
Westminster, MD
John Deere 3720 CAB/TLB, JD455
This rear diverter kit from BoltOnHooks LLC is designed to "split" or "double" the OEM electro-hydraulic 3rd SCV kit on the rear of model year 2011+ John Deere 3320, 3520, and 3720 CAB model tractors. This allows you to have a full TnT (Top-n-Tilt) kit or a HTL (Hydraulic Top Link) and a front grapple plugged in at the same time and switch between the two without swapping hoses, you only need to press a rocker switch placed in your right side console. Installation is fast and simple, with no permanent modifications to your machine. Installation should take less than 2 hours. This kit provides four Female 1/4" ISO 5675 "AG" style QD's to hook your hydraulic accessories to.
View them online here: Ken's Bolt on Grab Hooks <<Hydraulics>>
Specifications:
-> Maximum Flow: 10 GPM Max
-> Maximum Pressure: 3000 PSI
-> Voltage: 12 VDC
-> Current Draw: 4 Amps Max
-> Duty Cycle: Constant
-> Ports: 3/8" (-06) ORB (SAE) x6
-> Electrical Connections: Deutsch DT style sealed x2
-> Mounting Holes: 1/4 x5
-> Overall Size:4" w, x 6.25" h, x 5" d (without hoses)
-> Weight: 7 lbs 4 oz (with hoses and mounting plate)
-> Input QD Connectors: Male 1/2" ISO 5675 "AG" style QD's
-> Output QD Connectors: Female 1/4" ISO 5675 "AG" style QD's
-> Made in the USA
   / John Deere 3x20 CAB Model Rear Diverter Kit #2
Would this work on my 3046R cab model, are there any 3 way valves at this time?
John,
We are working on the ones for the newer 3-series "R" models, the mounting is different but otherwise it's the same basic theory.
If by "3-way" valves you mean 3-spool valves then no, there is just so little room available to fit more stuff into, this single diverter alone is a tight fit.
   / John Deere 3x20 CAB Model Rear Diverter Kit #4
Please let me know when you have something that will work with my 3046R cab model
2016 Isuzu NPR Cab and Chassis Truck (A51692)
2016 Isuzu NPR Cab...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A53843)
2004 FREIGHTLINER...
Ambulance (A51692)
Ambulance (A51692)
1995 Ford L8000 Grain Truck GARAGE KEPT (A53473)
1995 Ford L8000...
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
Epic Electric Cart (A51694)
Epic Electric Cart...
