john deere 336 balers
   / john deere 336 balers #1
dan28040
Bronze Member
Bostic, NC
Farmtrac 665
I have the opportunity to but two john Deere 336 balers for the price of one. Never been around one. Any affine of what to look for on them or how good they are would be appreciated
   / john deere 336 balers #2
They are a great baler but getting older. JD balers have been the same along time, the plunger bearing is often ungreased and ruins a wristpin. Gearbox should have oil, run them and make sure they tie.
   / john deere 336 balers #3
336 PH wrist pin is a bushing not a brg and have a history of grease worm damage. Check for looseness of PH in bale case. Check for bale case damage from rust caused by leaving hay in bale case when baler is not being used. Check flywheel bush for wear.
   / john deere 336 balers #4
Had one many yrs ago & it was new when I bought it. Here are the problems I had with mine.
* Plunger big end bearing needed to be replaced a couple times a season. Custom bearing for JD but with a sleeve one could use an off the shelf bearing. Big money saver IF you have a bearing supply house close by. The sleeve was custom made for the bearing ID.
* Had knotter frame break the first season. Replacement was a somewhat universal part and you might have to modify (either drill or increase the size of a couple holes in the replacement frame) to get it to work.
* At least on the earlier models the instructions for timing the needles was incorrect and adj to the manual would guaranty broken needles in no time. I lost 4-5 before finding out this piece of info.
* The tongue jack on the early models was a real widow maker. Within a couple yrs it was replaced with a different model. The bad jack functioned a lot like a bumper jack and if not real careful the handle could come flying towards you. Just missed my head one time.
   / john deere 336 balers #5
I remember no history of repeated PH crankshaft brg failures while I worked for JD dealer or since. I don't remember any errors in setting timing outlined in operators manual BUT would like to see a photo of that pages from OM showing incorrect timing info. If you continually broke needles you failed to read the section in the operators manual of the need for a correct functioning plunger head stop. If PHS is non-operable and baler isn't in time then needles will get broken.
2015 Ford F-450 Service Truck (A51692)
2015 Ford F-450...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2012 Harley-Davidson FLHX Street Glide Motorcycle (A50324)
2012...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
1264 (A50490)
1264 (A50490)
