John Deere 318 rear pto problem
   / John Deere 318 rear pto problem #1
Johng1233
Winnipeg
Hi, I a have a little issue with my 318 and hoping someone has encountered this and can help.
When I hook up the rear tiller for my 318 it turns on and works great. The moment I turn it off and then try to restart the pto it never turns on until I park it and use it the next day. Sometimes when I start the pto it engages about 20-30 seconds later.
   / John Deere 318 rear pto problem #2
Sounds like the air gap in the pto is to large. Use a feeler gauge and measure the gap i believe it should be about 7thousands of a inch. You can tighten the gap by tightening the three nuts around the outside edge of the pto. Be sure to tight each bolt a equal amount until you get the proper gap.
Thank you JD420
Peterbilt 377 Semi-Truck (A51039)
Peterbilt 377...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A51039)
3-Point Hitch Root...
