John Deere 318 deck tensioner pulley and arm.
   / John Deere 318 deck tensioner pulley and arm. #1
mblair441
Ira, Texas
1959 JD 730, 2017 JD 1025R, 1956 Ferguson 40, 1959 Farmall Cub, 1982 JD 318, Case 580B, JD 350B
On my JD 318 with a 50 inch deck, there is an arm that holds the tensioner pulley that pivots from where it bolts to the deck. The bolt to the deck has bushing through the arm housing through which the bolt goes. Is the bushing a press fit into the arm, or should it turn inside the arm housing, with the bolt turning inside the bushing? Thanks, Matt
New Long Forks (A53002)
New Long Forks...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
