John Deere 318 continues to surge.
   / John Deere 318 continues to surge. #1
Mtn.Mike
Northcentral Pa.
JD 2305
In checking other forums I learned that most surging is caused by leaks in the intake manifold so I took the manifold out, cleaned it, and put gasket sealer on it.
Everything was put back together correctly but I still have the surge. Can someone point me in another direction pertaining to stopping the surging?
The mower seems to run OK if using full throttle and engaging the mower deck but it starts surging as soon as the deck is shut off.
Thanks, Mike
   / John Deere 318 continues to surge. #2
Mtn Mike you have a dirty carburetor and or some dirt in the fuel system for sure. Get yourself a kit and rebuild the carburetor. If you go to youtube and rebuilding an owan carb there is a good video on how to do it........KJD
I thought that I would reply to this older thread. I ran a can of Seafoam through the carb and also put some in the gas tank.
I no longer have the surge so it was probably a dirty line or dirt in the carb.
Just an update to share with you.
Mike
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
New Holland TN70 Tractor (RUNS) (A50774)
New Holland TN70...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
