John Deere 318 charge pump whine
   / John Deere 318 charge pump whine #1
Hjfowler
Forest Hill, MD
John Deere GT275
My charge pump has started to make noise. It's almost like a grinding at idle, and then is a whine at higher throttle ranges. It's not the differential, as I know they tend to make noise when operating. When I bought the tractor (6 months ago) it didn't make a sound. I decided to replace the engine with a NOS Onan. While the engine was out, I powerwashed the underside as it was extremely dirty because it was missing a belly screen for most of its life. Hence the engine replacement. Also, while installing the new motor, I had the driveshaft connected and it got wedged in the metal hydro lines briefly because I wasn't paying attention. Now, the engine runs great, but I have this whining charge pump. I've changed the trans fluid twice in an effort to stop the noise. I've primed the trans filter. I replaced the suction hose and compression spring and there are no leaks. My only guess is I bent a fitting, or dislodged some grime that was plugging a leak somewhere that air is now being sucked into the system. Here's a link to YouTube, where I uploaded a video of my pump making noise. John Deere 318 charge pump noise - YouTube
Here is a link that is the pump after it warms up a bit and while at idle. You can hear how the sound just sounds like air or something is being processed through the pump. February 12, 2018 - YouTube
The sound also doesn't go away when the tractor is moving, so I don't believe anything is sticking.
JOHN DEERE LOT NUMBER 124 (A53084)
JOHN DEERE LOT...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2021 John Deere C12R Corn Head (A53342)
2021 John Deere...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
2019 Challenger MT738 Track Tractor (A53342)
2019 Challenger...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
