John Deere 316 No Lights
   / John Deere 316 No Lights #1
Firepuppy
Rome, NY
John Deere 316
I Have a John Deere 316 and when i put the motor back on the tractor i pinched the red wire that goes from the silinoid to the starter and it grounded out on the frame then when i turned on the key the oil light would come on and the battery light would come on and go out so i checked the fuses put 2 new fuses in there then i had both lights on the dash untill i turned the key i heard a click and now i have no lights on the dash nothing happens on the dash when i turn the key now is it possible i fried the silinoid down on the frame near the starter
Follow up;
ok i stared again with this and i finally got the lights to work again on dash but now when i turn the key on i hear the coil in the tdc box click and the relay near the starter clicks but that's all i get nothing else so that tells me im getting power all the way to the relay im waiting foe another relay i bought to see if thats the problem when i shorted out the red hot wire to relay and im going to change the key switch out cause when i took it out it was all rusty hopefully that is the problem can someone help me
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2007 Volvo VNL Truck Tractor (A53472)
2007 Volvo VNL...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
2015 F-550 Bucket Truck. (A53472)
2015 F-550 Bucket...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
