John Deere 3120 ehydro stuck in forward-won't start
   / John Deere 3120 ehydro stuck in forward-won't start #1
jldhome
john deere 3120
When I try to start my John Deere 3120 tractor it lunges forward like it is gear. If I put the transmission range gear in neutral it will start but then gears grind if I try to put the transmission in gear. The ehydro pedals seem to be stuck in forward;
Any ideas?
   / John Deere 3120 ehydro stuck in forward-won't start #2
Check the pedal mechanism and linkage. Clean and lubricate. Perhaps try a penetrating lubricant. See if you can get the linkage to center again.
I am more familiar with the pre-electronic hydro systems, like my 4600HST has. Maybe there's something going on in the electronics, but your description makes it sound to me more like a mechanical issue.
   / John Deere 3120 ehydro stuck in forward-won't start #3
I would start by putting the ICU into the diagnostic mode, and view the forward / reverse pedal positions using the display.
   / John Deere 3120 ehydro stuck in forward-won't start #4
Any ideas?
jldhome -
Did you get your problem solved? Those of us who answer someone's question like to hear some feedback about what the problem turned out to be.
After my earlier post, I wondered if it might be a stick caught in the linkage.
Happy tractoring, and welcome to TBN!
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
UNUSED 3/4 in. Polyester Arborist Outdoor Rope (A50860)
UNUSED 3/4 in...
