Buying Advice John Deere 310D
   / John Deere 310D #1
Martian
Elite Member
Earth
Deere
Hi all,
You've probably seen some of my threads about backhoes on here. I've been trying to figure out what I want to do and I'm looking at doing something a little different. I have found a 1993 JD 310D, just a base model, no 4x4 ext. hoe or anything, but it's only $11500, which leaves me with enough money to get that and keep my tractor. This way I have the best of both worlds. I guess my question would be if you recommend doing something such as this or should I look at a nicer tractor and get rid of mine. The 310D would do everything I need just doesn't have a cab and such.
   / John Deere 310D #2
A 310 is a great backhoe I have been in the construction business for several year now and I have used every backhoe made. John Deere has the strongest hydraulics probably on the market I myself am a case guy but I have seen and used alot of 310 510 and even 610 john deere machines. That would be a good buy
   / John Deere 310D #3
If this will get up and down your slopes without issue it would seem like it is more practical than the larger hoes you have considered. Keeping your smaller tractor is a smart move imo.
   / John Deere 310D
Definitely do like the Case hoes, just tend to like the JD 2 stick controls. Problem is I haven't been able to find a Case in as good of shape and as low of hours for the same price or I would definitely be leaning that way. I have always owned Deere so I do like the badge but have heard that Case has the best backhoe.
No real major slopes on my land, just some marshy areas, but definitely avoidable, figured I could get it out with the end loader and backhoe anyway. I looked at it today and it looks like a good size and the price is just unbeatable and like the thought of being able to keep my tractor, just not sure how much I like not having 4 wheel drive and some other extras.
   / John Deere 310D #5
A wise man would use the lighter 3x20 tractor for the soft spots and keep the 310 on terra firma to pull the little one out if it gets stuck.
I think you will find that this will be a better combination for you all the way around. First of all the price for the 310 won't get much lower with a little care on your part and the 3x20 is a good size to perform cleanup and leave at home for the winter snow removal.
From my experience with the 110 tlb (much smaller) the backhoe and 3 point hitch with top n' tilt is great. I still wanted another tractor dedicated to the 3PH work. Now when doing work similar to your project I have the backhoe and assorted buckets, the 4520 with heavy boxblade or landplane/grader and the 820 with landscape rake. Makes cleaning up a mess a much quicker project to complete. All that said I think you will be much happier keeping the small tractor.
   / John Deere 310D
Yes, I definitely wouldn't want to take it somewhere I was sure if I would be coming out. As I got looking at them more and more they seemed larger than what I thought and I saw more of a use to keep my machine and get a cheaper machine to have the best of both worlds made the most sense.
They have two of the same machines on the lot, a 1991 310D with 9000hrs and a 1993 310D with 3500hrs both priced at $11500 so I have been checking them both over extensively trying to find out why a newer model with less hours would be the same price on the same lot and the only difference I have noticed is that the 93 has a slightly longer bucket to the 91. the 91's bucket looks more industrial and a little shorter and longer but the 93s looks taller and skinnier and the welds seem to be different. Is this just a model difference and should I prefer one over the other?
The first is the 91 and the second is the 93... the front buckets just don't look the same.
   / John Deere 310D #7
9000 hrs. is getting up there for that tractor. I'd go for the lower hrs without a doubt.
   / John Deere 310D #8
Unless the hour meter has been rolled over, or replaced, or just quit working...
The bucket on the '93 model looks identical to the bucket on a '79 310A that I used for 3-4 days a month or so ago.
Single wall at the top lip and those "unique" chain-cable attachment points on the corners.
Pretty interesting running one of those 'ol hosses and comparing it to my 110! I could count to at least "one thousand two" for the reverser to fully engage! :D
But when you get all that iron movin' in one direction - things happen! :thumbsup:
AKfish
2016 Chevrolet Silverado 2500 HD (A44501)
2016 Chevrolet...
2010 Volkswagen Passat Sedan (A42744)
2010 Volkswagen...
John Deere Utility Cart (A44572)
John Deere Utility...
2020 Toyota Tundra Pickup Truck, VIN # 5TFEY5F14LX266984 (A44391)
2020 Toyota Tundra...
2012 TEX-MEX LOW BOY GOOSENECK (A45046)
2012 TEX-MEX LOW...
INOP/NON-RUNNING 2010 Ford F-450 Pickup Truck, VIN # 1FDAF4HR3AEB25362 (A44391)
INOP/NON-RUNNING...
