John Deere 3033R vs 3039R
   / John Deere 3033R vs 3039R #1
lduke1
Bargersville, IN
JD/2030
Looking at buying a new tractor and debating between these. Can't decide if the additional HP is worth the $
   / John Deere 3033R vs 3039R #2
All depends on your situation. The 33 will do everything that the 39 will do, just not as fast. The 39 will run wider PTO driven implements. The 39 will not pull any wider ground engaging implements than the 33, but it will pull that same implement faster.
So if you are not in a hurry to get things done, the 33 should be fine. But if you need-want to get things done a bit faster, then the 39 would be the way to go.
It's not often that you hear about people complaining that they have more HP than they need. My personal rule of thumb is to get the maximum HP in the frame size that I'm looking at.
Good luck with your decision. ;)
   / John Deere 3033R vs 3039R #3
Welcome to the forum! :welcome:
I'm going to move your thread on over to the John Deere section to see if we can get you some more input.
   / John Deere 3033R vs 3039R #4
The 3039r is my third JD of this size and the HP really makes a difference while plowing snow, mowing and pulling a land plane on my driveway.
If you are getting the cab then the extra HP is needed for the weight and AC.
   / John Deere 3033R vs 3039R #5
That's the group size tractor I looked at and ended getting the 46 HP, never heard anyone complain they had too much power.
Buy once, cry once.
   / John Deere 3033R vs 3039R #6
I have a Kubota L3200, pretty much equal to the 3039 if I recall. I occasionally have maybe up to $1,000 of regret for not buying the extra 7 odd HP for a L3900. It would have been over $2k more when I bought.
Tilling really taxes HP. Mowing my fields is as often limited my rough fields as HP. Roading with any kind of hills is HP limited.
Low range is mostly limited by traction rather than HP.
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2003 John Deere 1790 Planter (A50657)
2003 John Deere...
2000 WINNEBAGO FORD F550 RV (A50854)
2000 WINNEBAGO...
2022 RAM 2500 (A50854)
2017 Miller Nitro 6300 Self Propelled Sprayer (A50657)
2017 Miller Nitro...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A51039)
Adams FL24...
