John Deere 302A
   / John Deere 302A #1
mdwilkins
CT
MF 1030, 1949 John Deere B
Looking for opinions on a 302A. I have researched the data on the tractor and it looks like it will handle what i need. I need something to do genral work around 33 acres small farm. Move around the manure pile, drag the horse ring, work on the 1/4 mile drive, pull logs out of the woods for firewood etc. I will also use my 5ft brush hog to knock down about 3 acres of fields on a hill full of rocks and dips (let me tell you what a fun job that one is, your neck hurts after spending as much time looking behind as ahead). I have been searching and have not found much for reviews on the machine. What are peoples experience, I see good things about the 1020 which is the green version of the same tractor but very little on the 302.
Thanks.
   / John Deere 302A #2
I have a well worn 302A. great tractor. "removable" loader with turf bucket that will lift anything with enough counter weight. most parts are available. the 50HP 3 cylinder diesel is very loud but strong even at 6100+ hours. they did have a gas engine option also. Mine does not have a reverser trans and you are better off with out it. I do over all like the tractor.
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2021 New Holland C327 Compact Track Loader (A52748)
2021 New Holland...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
Air Reel (A50774)
Air Reel (A50774)
2018 Izuzu NPR (A50120)
2018 Izuzu NPR...
